Re: converting 65 Johnson from tiller to console
Welcome to the iboats forum brajo....<br /><br />You will need a bunch of "stuff". If your boat is not equipped with steering, you will need to install a steering kit. You can get a teleflex kit for as low as $175. All you add is the steering wheel.<br /><br />A control box for starting, throttle and gear shift as well as control cables. <br /><br />The engine itself will need an adaptor harness for the change over. <br /><br />If you could post the engine model number, that would be a big help in finding out if there are adaptor kits for your engine. Thanks.
