seabreeze101
Thread starter- Joined
- May 16, 2015
- 8
Hello,
I have a 1991 Johnson 100HP 2-stroke engine with OMC control box. The alarm in the control box audibles continuously upon turning the key -- even without starting the engine. The alarm normally beeps once when I turn the key prior to starting the engine.
I have read older threads (from 2003) in this forum that if I open the control box and disconnect the tan wire on the alarm, it would be an indicator of a faulty alarm or not. That is, if I turn the key and the alarm stays on with the tan wire off, then the alarm is bad. However, if the alarm goes off after I remove the tan wire, then it is indicative of something else (oil sensor, overheating, etc.). In my case, after I removed the tan wire, the alarm does turn off. However, I'm not so certain about the diagnostics in my situation -- I'm not even starting the engine. Would it still be a defective alarm issue? These alarms are hard to find but I did locate a used one on eBay for $50 but am hesitant to buy it if it's more than a faulty alarm. Any assistance is appreciated.
