CONTINUITY cable from transom to engine?
newtoboat101
5.7vortec /alpha 1 gen 1 ,the continuity cable from tramsom to engine, what do i use ,i do not see with cable kit and the directions have no number for this cable ,seems odd ,anybody have same issue and how did you connect ?thank you
tank1949
Mine have heave marine grade cables (tinned), which seem redundant since the cast iron block bolts to transom.
