Constant high pitch tone
Mark7516
I have a 93 johnson, im getting a constant high pitch tone when i turn the key, i see some threads saying the tone is overheat, but this tone starts as soon as the key is turned and engine is cool. Any suggestions?
Tim Frank
Re: Constant high pitch tone
A bit more info would help.
How long have you had this motor?
Did this symptom just start?
Does the noise stop when the engine starts?
Do you have an owners' manual?
Mark7516
I just got this pontoon, i had a compression compression test done before i bought it and it was fine. I went yesterday to put it in the lake and couldnt get it started I noticed the fuel bulb was cracked, i replaced it and it and the engine started right up. ( a side note on the bulb, it stays soft, wouldnt really get hard) Like i said as soon as i turn the key not starting the engine the tone starts and it continues when the engine runs. it almost sounded as if fuel flow was restricted to the engine. but i wonder if that would explain the constant tone even before startup.
Joe Reeves
That sounds like it would be the warning horn. I'm not familiar with the 1993 engine but I assume the warning horn is the same as the earlier models such as the 1989,90,91,92.
Locate the horn. The TAN wire should be on a slide on terminal closest to the horn's built in black ground wire. If on the opposite terminal, weird things will happen.
If the TAN wire is where it should be..... while the horn is sounding, remove that TAN wire, if the sound continues, the horn is faulty and will require replacing.
If when the TAN wire is removed, the sound stops, then either that TAN wire is grounded somewhere or one of the sensors at the engine is faulty. If a faulty sensor, disconnect a sensor one at a time.... when the sound stops, you've found the faulty sensor.
Mark7516
Thanks for the advice, i did disconnect the tan wire and the tone stopped, i disconnected all wires, re connected them and it actually worked as it should, make a quick tone at the turn of the key and stopped. It then went back to the constant tone after a few minutes later i tried it, i did this process a couple of times, i think it might be a faulty horn? what do you think? i was going to try a new one. Thanks a bunch
Joe Reeves
Reread the 4th paragraph of my original reply.
Mark7516
Ok, while the buzzer was sounding, I started messing with the wire that goes into the oil tank and just happen to move the extra wiaround the buzzer went of, guess its something with the oil sensor. as of now it works fine.
Thanks
boobie
Just so you know, OMC had probs with the oil tanks giving off false signals prior to1996. The next time it happens, disconnect the wires going to the oil tank and see what happens.
