Overexposed
Thread starter- Joined
- May 10, 2019
- 2
Hope yall can help have been chasing my tail on this one.
I have a 95 johnson 225 and recently its been sounding its constant alarm when you get on plane and put the throttle down. So i looked it up in the service manual and it says that alarm is over heating, so I go threw and replace the 2 thermostats and throw a new water pump on with the new housing and wear plate and so forth. Doesn't fix the issue had 10 pounds at idle and while underway has 30 pounds so its not water flow (unless there is a blockage somewhere). so I threw a new VRO pump on had a new one as a back up just incase. wasn't that.... I took it out and when the alarm goes off its a constant alarm when your getting into the throttle but as soon as you pull out it goes off that was happening at about 4000 RPM then I ran it at 3xxx rpm for a while and it started to sound the alarm off at that speed also and so on as I kept running it started going off at slower RPM.
Any advide would be greatly apricated!!!
Thanks , Jeff
Thanks , Jeff
