Connecting Lowrance GPS to Smartcraft Gauges
Eddie B.
I've been trying to get this wired up for some time with no success. I need help!
I've tried wiring Yellow wire port 1 to White/Blue stripe to scand shield to Blue w/white stripe. NO luck
I've tried all above except using com port 2 Blue.
I also tried wiring to orange wire even if receive wire.
I then tried shield, Blue with white stripe to a ground under dash.
I think I have all proper entries on sc gauges.
I need help!
QC
Re: Connecting Lowrance GPS to Smartcraft Gauges
Moved this over to Electronics, Eddie. Those brains hang over here ;) Welcome aboard!!!
Eddie B.
I have been wrestling with this for some time and I know there is some small something I am missing. Its to 28chd to 08 smartcraft gauges 08.
So far I've tried onnect the sc (+) or white with blue stripe to com 1 or yellow.
Then I tried the orange as noted on another page. No luck.
Then I tried and have it connected to com 2 or the blue wire.
The sc (-) or blue with white stripe I had connected just to the shield wire. NO luck.
Then I connected also into a ground under dash no luck
Then I ran a ground back to battery no luck.
Baud rate I am using 4800
I also have GL:L and GGA checked. I have also tried with GSA&GSV both checked and not checked.
Iam at my witts end! I need help!
Eddie B.
Eddie B.
Sorry I got on wrong forum. I am new and just missed the electronics forum.
Thanks for setting me straight.
Eddie B.
QC
No problem Eddie. I merged the two threads also . . . we'll get this right yet, and hopefully a response or two :)
Eddie B.
TTT
I hope this works because I need the help! I am thinking maybe ground I have a good ground but not sure of common ground? Also maybe a download or update on Lowrance units maybe?
bruceb58
Honorary Supreme Mariner
Do you have links to the manuals of each? I 'll take a crack at it for you.
Just be aware that usually, all shields get tied together and get tied to ground.
Rotorfixer
Hello,
What model of GPS are you using, and I assume you are sure it is sending NMEA 0183, not NMEA 2000 right?
