Connecting hour meter
StanPiot
We have a 2006 Trophy 2352WA and have installed an hour meter. Does anyone know a reasonably simple way to connect the hot lead to the ignition circuit (purple wire)? The ignition switch is inaccesible short of using an axe and a wiring bundle blocks most of the rest. Help!!!
Silvertip
Honorary Supreme Mariner
Re: Connecting hour meter
You are making this way more difficult than it has to be. An hour meter has two connections. 1) +12 volts and 2) ground. Ground can be connected to any of the ground terminals on any of the gauges (assuming the meter is installed in the console). +12 volts can also be connected to the +12V connection on any of the gauges. Why? Because the gauges are active when the key is turned on. The hour meter is not dependent on the engine running and is not designed that way. It is simply a 12 volt clock mechanism. It runs as long as the key is on. Since the key is not normally left on when the engine isn't running, it is fairly representative of engine hours.
