minuteman62-64
- Apr 12, 2011
- 1,350
I know for marine applications the preferred way to connect wires is with crimp connectors. I've had good success (i.e. zero failures) with crimping same-sized wires (#16 to #16) and close to same-sized wires (say #16 to #18). However, I have problems with a difference of more than one wire size.
I'm connecting #16 wire to wire quite a bit smaller (looks to be either #20 or maybe even #22). I've been soldering wire all my life (at least from pre-teen on) and am much more confident in soldering these two wires than I would be with a crimp connector.
What would be the issue(s) with soldering these connections, heat shrink tube over and then covering all with the liquid tape compound?
The connections would be to a sensor mounted on the cylinder head. Consequence of failure would be loss of an add-on overheat alarm.
Or, is there a technique for crimp connecting different size wires that I should be following?
