confused
steven88venture
Ok i have a 87 150 gt johnson and i am having a issue with well i dont know what the issue is i got it not long ago and it wouldnt run due to carbs i did a full cleaning with kits and new gas with a inspection of reeds and carb sync but now # 1 and 2 plugs are getting very black and i know its not carbs cause i swapped that carb to the bottom but the issue didnt move i dont know what else to check oh and compression is perfect on all 6cyl
boobie
Re: confused
Will the spark jump a 7/16" open air gap on a spark tester ??
dwco5051
Re: confused
Does that engine have the butterfly chokes and not primer injection? If so have you ran it with the silencer off and observed that the chokes are operating together? Just a guess but it may be a problem with the choke linkages not permitting the top carb's choke to open properly. It may seen right when operating the choke with the engine off but a problem with the linkage may permit it to suck shut with air flow. As I said just a wild guess but easy to check and rule out.
Silvertip
Honorary Supreme Mariner
Re: confused
It is either running rich on the top two cylinders or you have weak spark on the top two cylinders. Have you done a compression check. You may have a mechanical issue.
steven88venture
Re: confused
Those 2 top plugs are turning a dry sooty black if tha gives any more help
