Engine E140TLCEB confirmed on the engine plate. The idle is #41(lower), the upper intermediate is #51, maybe #54. It's back together right now so I will confirm next time I open things up.
My initial thinking was more air would draw more gas but apparently not. A bigger jet just lets more air in, got it. I might switch the idle and intermediate as a test only to see if it leans out a bit at idle. Right now, it's sooo rich that after two hours of running, then docking and shutting off the engine. Immediately pulled out plugs and they were wet with fuel. In fact the outside of all four carbs are usually covered with a gas film. I replaced all the gaskets, floats and properly adjusted the floats.
It's an old tired engine I know, with compression within a couple pounds of 95 across all four. When it sits overnight it floods the next day and that's with the choke system disconnected! BTW, once it starts, it continues to start and run until the next day.
