Condensation problems with Humminbird 718
Wis Bob
Anyone having internal condensation problems on Humminbird units?.
In the fall of 2009 I was fishing in somewhat cold conditions. When the sun was shining on the back of the unit, the full screen had condensation on it. As the day got warmer, the condensation finally dissipated.
Also having a problem with digital depth. Digital depth jumps between the actual depth and the second echo depth. Example: actual depth 15ft. The digital reading jumps back and forth from 15ft to 30ft. This happens repeatedly when using the unit on a river where there is a fair amount of current.
John_S
Re: Condensation problems with Humminbird 718
I've had some condensation like you describe on older Wide units, but not on newer 700 series. If yours is still on warrantee, get it into HB so you can have it back for the season. also, update the S/W with the latest version. If you have an SD slot it is easy, otherwise need a special cable. If you are sending it in, HB will probably update it as well.
