is this one myth or fact.. ????<br /><br />look at all the condensation that forms on your car widshield every morning and then think of this happening on all the metal surfaces inside your fuel tank.. then feel the desperate need to make sure its as full as possible to cut down both on air volume and exposed surfaces inside the tank.. all sounds logical.. but is it..??<br /><br />there are a couple of good reasons for not filling the tank if u dont have to.. folks seem to think that gas goes bad very quickly and secondly its money better in your pocket than sat dead in your fuel tank.. especially in areas of the world where it would cost 400 US dollars to fill a fifty gallon tank..<br /><br />anyways take a fifty gallon metal tank.. sometime in the fall/autumn put five gallons of gas in there and seal it up.. leave to brew for five months over winter in your backyard then open and inspect gas.. ????<br /><br />useing the windshield analogy the stuff would be pretty watere-logged but based on the simple logic that a certain volume of air can only contain so much water and there is no reason to believe that its all gonna end up in the gas.. there wouldnt be much at all..<br /><br />okay so a gas tank in a boat might not be 100% sealed but if not it could easily be made so.. <br /><br />okay so i cant fault the "better safe than sorry" arguement and praps in todays every-rising price of gas it might make sense to stock up on some in your boat.. but somehow i cant help but feel that the not filling your tank over winter leads to water-logged gas theory is based more on mythology than fact..<br /><br />at the worse a spoonfull of water perhaps.. easily diluted with the addition of twenty gallons of fresh gas in the spring would solve any winterization problems to me..<br /><br />also the gummed up carb theory isnt caused by one float-chamber of gas evaporating over winter its caused by many many float-chambers of gas evaporating due to excess heat in engine compartments everytime the boat is run.. which over time might/does lead to problems..<br /><br />just a thought.. or some thoughts..<br /><br />trog100
