R Socey
- Jan 9, 2011
- 501
Re: Concrete help ?
You have made up for it with some useful info so I forgive you whether you like it or not. I am going to bite this off - the savings is well worth it. I do appreciate your help. Maybe I'll teach you how to catch a big cats - forget the sabiki rigs. Strike that - you can use those to catch bait!
My whole life people have told me: you need experience to do this or that. What better place to learn than on my own job. I pick up hands on stuff real fast, and I am very cordinated. You have to climb on a bull to ride a bull - your remarks were out of line.No, actually it was my foreman at the time which gave me an even bigger kick!
I can honestly say I've done my share of the "bucking bronco" (you'll see what I mean) though. It's not as easy as it looks.
Equipment operators may not look or be very smart, but good ones are hard to come by and worth their weight in gold.
... but what about ceement? You know, ceement floors and ceement walls! I like to tell the people that use that term that it's concrete and cement is just one ingredient of concrete.
Here's a tip for Socey:
Over excavate and back fill with granular fill, most use 57 stone but I prefer 89-10. Grade you fill flat and uniform, thick and thin spots in your slab will cause undesirable cracking outside of control joints.
Ask your contractor about cut control joints instead of tooled, cut joints are deeper, usually straighter, and narrower.
4000 psi concrete withstands the elements much better than 3000, especially in a freeze thaw zone.
Rebar on chairs is much better than WWF. After the wire is tromped on by the finishers it's always at the very bottom of the slab and will rust to nothing in time.
Don't let your contractor add too much water to the concrete before placing, one of the biggest and most common mistakes made when placing concrete. If the mix "breaks" over the blades in the concrete drum on the truck, it's too dry. If the mix looks like split pea soup and comes flying down the chute it's too wet. The mix should flow over the drum blades without breaking, but be thick and come out of the end of the chute like tapioca pudding.
Ask your contractor to use a vibra strike of similar method of consolidation when placing the concrete.
