"Computer" in Johnson 90 hp Needs to be Replaced
HRGuyinSC
Hello,
I have someone repairing my boat and they said the "computer" needs to be replaced in my 90hp Johnson outboard. I can't seem to find any info about replacing a "computer" online, so I thought I would make sure this is a legit replacement. The quote is $1500. Any insight is appreciated.
Thanks!
GA_Boater
What 90 HP Johnson are you talking about? It helps to know. :joyous:
Honorary Supreme Mariner
These motors are not " all the same "----Therefor you need to provide ---Year / model # / 2 stroke or 4 stroke.
Evinrude57
That is a fuel injected motor, the "computer" that he is referring to is also called an Engine Control Module (ECM) but could also an EMM, ECU, ICU, many different terms for the same item, and yes $1500 is in the ball park of what they cost to replace. The Johnson 4 stroke was a rebadged Suzuki, so if you can find a one for a suzuki for a better price then that would work too.
The BRP part number if you are correct that it is a 2003 Johnson 4 Stroke is 5036046 and has a List price of $1571.99.
HRGuyinSC
Thank you very much. You have given me piece of mind before I shell out 1500! I sincerely appreciate the help and guidance.
