Re: computer clean up
If win95 or 98, or 2000 you need a boot disk to get into dos. Booting to "Dos Mode" will not let you format the hard drive.<br /><br />A old DOS Install Disk #1, or a win 95/98 cd rom bootable installation disk will also alow you to boot directly into DOS.<br /><br />If you are putting windows 2000 or XP on it, you don't have to worry about formating first, because one of the first steps in the installation process, it asks you if you want to format, or leave the origonal file system intact. You just select format. Use NTFS instead of FAT32. The ONLY benifit of using FAT32, is if you ever had to physically remove the hard drive and put it in a win98 machine to view the files, any chance you will ever be doing that? probably not.<br /><br />If you need any help in your re-installation, or want some more tips, let me know.
