Compression
Status
Not open for further replies.
mobgod
Hi all i'm new to the game need to know what should be the Compression on a 200TLX77C cant seem to find the info for this
BonairII
Re: Compression
Did you do a compression check yet? If so, what did you get?
mobgod
Can anyone help me out with this ?
SENT FROM MY ROOTED 3D
Solittle
Re: Compression
Some patience would be in order me thinks.
You said your compression was 80 - - For meaningful feedback you need to provide values by cylinder for all six.
mobgod
Can you please explain what you mean by that
emdsapmgr
Re: Compression
If that engine has the stock 456/457 heads, you should get about 110 lbs on each cyl when cranking.
mobgod
Ok how do I check to see what heads I have
nwcove
Re: Compression
geez......just check compression on all cyls and post back, it can be narrowed down after the results
emdsapmgr
Re: Compression
The part number of the heads is cast into the side of each casting. Look for the numbers: 323456/457. I'd suggest retesting with another compression gauge. Not all of them read the same...
mobgod
Ok thanks but I think my numbers are different does that matter also what should it read for the psi
emdsapmgr
Re: Compression
It absolutely makes a difference in what heads you have on that powerhead. In the mid 80's OMC went to the low compression "bathtub" heads on many models. They run significantly less compression, perhaps even down to 85-90 on each cyl. If you have those low compression heads on your engine, it's important to know that-it will tell you if you have a possible internal powerhead issue, or if it's just normal. If you are running stock factory carbs and jets, it won't run well on those low compression heads. Poor holeshot and weak midrange are symptoms.
mobgod
Ok so the best thing for me to do is get the model of the heads and post back correct
mobgod
Hi again guys can you tell me a good place to get plugs for my motor west marine wants to much money any online place
mobgod
Not sure if anyone seen my post can someone point me to a good place to get spark plus got this motor I know I need ql16v but west marine wants to much money
Status
