compression
master chief
12FOOTER,I already installed the inline fuel pmp.The last thing I did was replace the fitting on fuel tank and cut the fuel@ end, cause of cracks in hose.I have,nt tried it since I did those.I tried it after I put in the pmp,with no change.I,ll put her in the water and see if that helps.I was just wondering where the manufac usually installs the anti siphon vlv.<br /> master chief
12Footer
Re: compression
That would be in the fitting at the top of the pickup tube. If there is no ball in there, they probably removed it for you.
