Silly Seville
Thread starter- Joined
- Dec 5, 2009
- 798
Is it the same for 4 stroke automotive engines? I ask because I'm perusing this forum trying to learn as much as I can about my new-to-me Johnson 85 hp V4; and need to know what I should expect from the readings to decide if this engine is healthy enough for service. It is not actually running yet as I need fuel lines and such, but I did perform a cold compression test (40 degrees in garage) and am getting 115-130 psi. Can I safely assume that those are good readings since cold temps typically result in low readings? BTW, I did squirt oil into the cylinders during each test to prevent scuffing a cylinder due to lack of lubrication. I also held open the carb butterflys manually. Other than the cold test conditions, did I do everything correctly?
Thanks!
Thanks!
