compression.test
Davidmerc140
compatible swap for mercruiser 140
Looking for another engine to swap out blown 140 engine. Out drive#3841985 engine #3681706 choices are 165 or 120
Davidmerc140
Re: compatible swap for mercruiser 140
165 is a 1971 my 140 is a 1970 not sure on year of the 120
thumpar
120 would swap in no problem. The 165 is most likely the inline 6 which would take some mounting work or the 3.7l which would also take some mounting work. Either way with a 165 you would need to change drive ratio or try to compensate with a prop.
achris
More fish than mountain goat
Re: compression.test
Thinking it over will a 120 or a 165 drop in and be compatible?
120 would drop straight in, but that is not the way you really want to go. With a new front engine mount structure on the bottom of the boat, a 165 would also drop straight in, but you would need to change the gear ratio in the upper drive.
Chris...
Yea i called a machine shop today they qouted between 1500 and 2000
Still set on doing it myself accept the machining need a shop manual for this engine from there i will make decision to move forward or pay to have it done thanks for advice
having done my share of rebuilds, you will save about 3 hours of labor doing it yourself assuming you have the proper tools.
for the price of a rebuild, you could get a complete and running engine for much less, strip it down to the long block and swap it in place. then again for $2k you could buy a complete running boat.
achris
Why wouldn't I want to go with the 120
You'd be going from 140 horsepower to 120 horsepower, and a similar drop in torque. The performance difference would be very noticeable. I have done quite a few re-powers going the other way, and people always say the same thing, "Why didn't I do this years ago"....
Just saying.....
the other reason is that the 120hp (2.5 liter or 153 cubic inch) engine has not been in production for over 20 years, where a 3.0 / 140hp is still in production and can be found everywhere.
Davidmerc140
165 will be compatible with outdrive?? Need to purchase mounting bracketsor modify
the 140 and the 165 will have a different gear ratio
