FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Preparing to test compression on my 175 HP V6.
1. Should I use the muffs while spinning engine for test?
2. What is the best way to disable engine from trying to crank while testing?
If you have a starter solenoid, you need to run a jumper wire from a 12V source to the positive side of the coil for the solenoid. That will crank the engine without needing the ignition.
