Compression test result question
josh_scci
Ok so I ran a compression test today with a borrowed gauge and it wasn't a screw in you had to hold a rubber boot in the plug hole. Also I dont know if it matters but it was also missing the glass. Anyway the results where 65psi on both cylinders on my 1985 40hp Johnson. This seems a little low but I suspect the tester may be faulty. What are your opinions?
Rick.
Re: Compression test result question
I would try hard to get a different gauge before I got too worried. Best of luck. Rick.
josh_scci
Also the engine starts and idles like a champ. Starts first time everytime.
AlTn
are you just looking for things to worry about?....did you do the compression test as a baseline?
josh_scci
I am having some issues at WOT with surges. Doing a compression test was one of the suggested tests.
AlTn
ok..have you checked all the fuel line connections for cracks and tightness?
josh_scci
I actually replaced all the fuel lines yesterday and took it out today and it ran strong all day and didn't surge once. Thanks to everybody for all the advice.
lifeboat
Must be a pull rope to have that kind of compression and still run good all day
