Re: compression test on 1999 Johnson 90 hp
All the plugs removed and do one cylinder at a time. I would also recommend the engine be cold if possible (not run for at least an hour).
Use only a screw in compression gauge not one of those crap ones with a rubber nozzle.
All cylinders should be within 10% of each other.
