Compression test! 1985 mercury outboard
B-Dozer
tested the compression on my 1985 mercury 90hp inline 6 125-120 on the 5 I could test, but now I have no spark.Did I hurt something by not grounding my plugs during test ?
hl
Re: Compression test! 1985 mercury outboard
I hope you either turned the kill switch off or grounded the plug wires if you pulled all the sparks out while testing the compression. Some people belive you can damage the stator or switch box because the electrical system can back up and cause problems.
B-Dozer
I didnt ground anything so I'm guessing I messed up something electrical. I'm sure what I did is going to be the most expensive part. Lesson learned
