compression results
harleymike
Did a compression test on my 96 force 75hp.
#1 is 131
#2 is 127
#3 is 131 psi
are these no.s in the right range for the motor.
thanks for all the help
mike
BuzzStPoint
Re: compression results
Next take a bit of oil and squirt it into the #2 cylinder and re do the compression test.
I dont know the original specs but typically if the ranges aren't low and and within 5% it should be good.
Your numbers look good, but I'd still try a tad bit of oil in that cylinder and see if it comes up.
JB
Your compression is fine, Mike. No good reason to fuss with it.
