Compression results for my 1976 Chrysler 55HP
turtle1173
Hi,<br /><br /> Well I finally got a compression guage and went out this morning to check it out. I warmed the engine for several minutes before taking the results. Here it is:<br />Top Cyl.: In neutral - 157: WOT - 169<br />Bottom: Neutral - 156: WOT - 165<br /><br />Does this seem high to you all? Does that mean anything? I've been putting off doing this for a long time because I was afraid of what I might find. Are these results too high? If so, what causes it and what can I do? I don't think I've ever heard of too high of compression but who knows??<br /><br />shane
G DANE
Re: Compression results for my 1976 Chrysler 55HP
Hi Turtle<br /><br />Compression is great - not the thing to worry about. Sounds like you got a good sound engine.
crazyray
not sure on your post to check compression you remove all spark plugs.....spin motor over with starter 3 -4 revolutions....is this how you did it?......just had the impression you had motor running?.....if so your readings are not accurate...........hope you get it going and enjoying the water soon
turtle1173
I ran the engine several minutes to warm it up, shut her down, removed both plugs and then did the compression check.<br /><br /> Well I'm glad that's one less problem I have to worry about :D <br /><br />Thanks,<br />Shane
