i know the readings are supposed to be within 10 % of each other, but i just bought from ebay this 72 50hp and the readings about an hour ago were 160 on both ! is that TOO high... how high should they be? <br /><br />web page
phatmanmike,<br /><br />Are those your readings or the sellers?<br /><br />That seems a bit high, but I think I might suspect the guage, before I did the engine. HMMM! Interesting!<br /><br />Does it run?
hello<br /> my 71 50 is 180 on both<br /> its normal<br /> those engines had a small s shaped combustion chamber<br /> but they do have a nice exhaust bark on a flusher <br />good luck and keep posting
hello<br /> good design I guess.<br /> actually I think its the combustion chamber design. its really strange. the 68-71 3 cyl used it as well posibly even the 72 models. compression ratio does not always reflect combustion chamber pressures either.<br />same as my 1970 442 w-30 with one or two engine mods always ran well on 89 octane unleaded. ran better in the late 70's early 80's when shell still sold 98 leaded but oh well.<br />160- 180 was a common figgure then<br /> the 7.4 that I put a head on today runs 175 and its like 8.5 to 1<br />good luck and keep posting
