svillebrian
Thread starter- Joined
- Jun 29, 2008
- 41
I have a 2001 johnson 90hp 60 degree. I'm getting ready to pull the plugs and check the compression. I think I have a bad head gasket. Does anybody know what the compression would be? Also, if the compression is bad and it is the head gasket as i presume, when i tear it apart, what else should I look for to make sure no other damage or problems have occured with getting water into the cylinders...
