Compression Problems
rko61
Compression on my 1976 70HP Johnson is 120, 120, 90. Is there anything I can do short of a complete rebuild to get back to fishing this year.
oldcatamount
Re: Compression Problems
You can try running some Sea Foam through it. With the motor running, squirt the Sea Foam into the throat of the carbs until it stumbles, let it recover and do it again. Run the whole can through it and re-check the compression. Changing the head gasket might do it as well. The gasket won't be to expensive and you can do it yourself, just be sure to re-torque the bolts correctly.
Honorary Supreme Mariner
Remove cylinder head for inspection.----If head gasket is bad replace it.----If damage in cylinder you should not run it anymore till repaired properly.
