Re: compression problem
You may want to get a closer look at the ringset on that low compression piston. Suggest you remove the side cover on the block for that cylinder. (called a bypass cover.) Once removed, you can view the piston rings and piston skirts for carbon buildup. Slowly rotate the flywheel by hand to see if the rings appear to move freely in their groves. Not a difficult thing to do, but you will need a new cover gasket (307133-about $2- when you reinstall it.) Original factory pistons in that year were unusual. The top ring groove is cut right at the top of the piston. While that yielded max compression, it was a long-term potential failure (weak) point. After a year or two, OMC re-designed the pistons and moved the rings slightly lower on the piston. While NLA, racers still seek out these old pistons for their performance potential.
