Compression on 85 Evinrude
Joe Reeves
Re: Compression on 85 Evinrude
Usually in the area of about 100+ psi and even on all cylinders.
What readings do you have?
bufordg
around 90 and motor has not been run since 07 checked it before we started it
durban
Master Chief Petty Officer
the manual says 92 .6 cubic inch per piston = 1 195 200.00psi per1000 feet/psi/1000 feet
emdsapmgr
Normal compression would be in the range of 125 psi when new. Those early crossflows run higher than later models.
boobie
Joe, I really agree with the " What " ??
laotou
Mine is 76 85HP. Compression is 92 - 95 psi.
