Compression on 1988 175 Johnson
Chum Slick
I have 90 lbs compression on all 6 cylinders. Is that a little low? Someone told me that the V6's compression was normally lower than the V4s. I have a 120 looper that has 125 lbs on all 4 cylinders.
JB
Re: Compression on 1988 175 Johnson
You are fine, CS.<br /><br />Good luck. :)
Chum Slick
Thanks JB. I knew someone would set me straight.
