OkieFromMuskogee
Thread starter- Joined
- Sep 8, 2020
- 2
Does anyone know what the compression should be on each cylinder on my 1962 Johnson 2-stroke FD-16? I got a reading of 50 psi on the bottom cylinder and 55 on the top. I'm assuming it should be around 100 psi on each. If compression is low on both, should I be thinking rings, cracked head, or blown head gasket? Thanks.
