compression numbers on 1992 Force 90HP
dcar00
I did a cold(not right I know, didn't have muffs with me) compression check on my 90HP 1992 Force.
110
120
120
Is this good, bad, OK?
I'm thinking about doing a decarb with seafoam in the 1 gallon tank I saw on the other sticky thread.
should I see better after that?
JB
Re: compression numbers on 1992 Force 90HP
Nothing wrong with those numbers, dcar.
A decarb wouldn't hurt, but don't expect it to help a lot either.
imported_LakeRunner
Just don't run the motor out of the water or on muffs. Decarb may help free up a sticky piston ring but those numbers are close so you may see a few points rise but don't expect miracles. You can also squirt in some Lucas or Marvelous Miracle oil in the cylinders after you do your decarb to lube the cylinders up.
