compression issue
tiller man
tohatsu 18 hp 4 stroke no compression top cylinder. could this be a sticking valve. when running sounds like it fires ocassionally.
MattFL
Master Chief Petty Officer
By pulling the rope. Start by making sure they're all moving and no parts appear to be bent or missing, then check the clearances against spec. The clearance info is sometimes on a label on some motors, or it will be in the service manual for sure. Also take a look at the spark plug and look for anything unusual. Is the electrode missing or damaged, is the spark plug shiny and clean or rusty (indicating a water leak into the cylinder), etc..
pvanv
Could be a lot of things. Do a leak down test and check by cranking as matt suggested.
