Compression compared to cyl. Leakdown
Londog
have 1992 175hp Johnson faststrike with bad compression and cyl. leak down. #1=90/19%, 2=90/19%,3=90/20%, 4=85/15%, 5=78/14%, 6=78/14%. I realize I'm looking at a rebuild, but what I don't understand is why the leak down readings go down with the compression readings. I guess I would have expected the opposite?
tpenfield
True, you would expect a higher leak rate (%) with the lower compression numbers. The only thing to think about is that compression is a dynamic test (pistons moving) whereas leakdown is a static test, piston not moving.
So, how the piston rings react to movement and compression may be different with the dynamic test. i.e the rings are 'seating' better on the 'looser' pistons.
boobie
I'll stick with a compression test for a 2 stroke. But for a 4 stroke you can't beat a cyl leak down test. Remember, we have valves that can also be bad.
