Compression Check 1992 225 Johnson
Mattash
I have purchased a compression meter. I 'm wondering what is the best way to inhibit spark. Disconnect all the plug wires and turn her over or remove the lead to the powerpak, or......????.<br />Thanks
Dhadley
Re: Compression Check 1992 225 Johnson
Pull the kill switch lanyard or jump the starter solenoid with the key off.<br /><br />Good luck!
