compression 1998 johnson 115
awol1
Four cylinders: O 125 O 80 <br /> O 125 O 125<br /><br />Is this a bad cylinder. Is there anything I can try to "fix this" before a rebuild. Can you rebuild just one cylinder? What is in my future if no repair is done? The motor runs fine at speed but has started to idle roughly and stalls.
JB
Re: compression 1998 johnson 115
Ahoy, AWOL.<br /><br />Looks bad, but there are a couple of things you can try.<br /><br />Compression can go away from carbon fouled rings or from a blown head gasket, as well as more catastrophic failures.<br /><br />What does the spark plug from the bad cylinder look like?<br /><br />Try squirting about a tsp of oil into the cylinder and try the compression again. Big improvement? Piston/ring sealing problem. Could be carbon. Decarb the engine.<br /><br />No improvement? Pull the head and look for a headgasket failure or major scoring of cylinder walls.<br /><br />Let us know what you find. :)
awol1
the cylinder is the upper right when looking at the back of the engine. The plugs all look the same. no visible head gasket problems.
thosch
I believe that the upper right (starboard) cylinder that tends to carbon up first on the v-4s. I remember dhadley's comments about moving the pee line connection to the top of the block on that side, and greatly reduced the carbon problem for that cylinder. Might be a long shot, but a decarbon job is worth a try before tearing into the engine.
