Compression 1998 E200TXECM
jjhjrcmh
I checked compression on all 6 cylinders and found them to be 85,85,85,90,90,85. Is this good?
SparkieBoat
Re: Compression 1998 E200TXECM
it is ok...you should go to secret files section and try the decarb.
jjhjrcmh
Thank you very much. Just bought the sea foam.
jjhjrcmh
Did a decarb now all are at or very very close to 92-3 psi.
JB
That is fine, jj...etc.. The big V6s normally compress lower than 100psi.
SparkieBoat
thats great...motor should run like a top for you now.
jjhjrcmh
Thanks, have a safe and wonderful 4th
