Compresion
Captin Dilly
I just did a compresion test on my 1989 Johnson 110 cylinders 1&2 are at 110 psi, 3&4 are at 120 psi. Is this a simple case of torgueing the head on 1&2 or am I looking at something more serious such as rings or worse? By the way...this forum has been such a huge help already, thanks in advance.
The Captain
Daviet
Re: Compresion
As long as they are within 10% of each other I wouldn't worry about it. You might gain some by replacing the head gaskets.
Captin Dilly
Re: Compresion
Why then, Im I fouling Plugs....Rapidily? Within a couple of days.
Daviet
Re: Compresion
Correct plugs?
Carbs running rich?
Spark jump a 7/16" air gap and is it bright blue?
Captin Dilly
Re: Compresion
Yes, Correct Plugs. I will check spark jump and color. Thanks
Daviet
Re: Compresion
Didn't say anything about overheating and running rough.
Check the spark and see if it is up to par.
It only runs rough when it overheats?
It is possiable to have a defective head gasket that allows compression into the cooling system, causing it to overheat, but still have acceptable compression.
Running rough when it over heats could be a coil breaking down when it gets hot, need to check spark when it is acting up.
BUT, you need to correct the overheating problem first so that you don't cause major problems.
Daviet
Re: Compresion
Several componets in your ignition system, go to the CDI website and look up your engine, use their troubleshooting guide to help you find your problem.
A quick check on the coils, swap the coil with no spark for a coil that does have good spark. If the no spark condition moves with the coil, you have a bad coil. If the no spark condition stays on the same cylinder, go to the CDI website.
