AguaSki
Thread starter- Joined
- Jul 4, 2005
- 545
1. 1978 Glastron SSV-188
2. Length 18?, Beam 88?, boat and motor together should weigh approximately 1,500 lbs.
2a. Don't know the recommended hp, but max hp is 150 hp
3. Two adults & two Children. Total weight is 171 + 126 + 61 + 53 = 411 lbs. Gas is normally 15-25 gallons
4. Water sports with the kids (tubing and skiing)
5. Think I have a deep-v. Not sure about the deadrise, but the sales brochure says transom width is 84.75?, and the depth is 45.75?
6. 1978 v4 Johnson outboard
7. 140 hp and 2.0 gear ratio
8. Manufacture recommends 4,500-5,500, but I see a lot people on this forum recommending 5,800 as a target.
9. About 1? above keel
10. No
11. Yes, Nauticas Smart Tabs installed. No hydrafoil or dolefin
12. Michigan Wheel, Apollo, 13.375 diameter, 15 pitch, SS
13. WOT is 5,300 RPM, 35 mph (GPS verified), 25 gallons, 411 lbs in passenger weight.
14. Normal operation is at 1,700 feet above sea level.
15. Three seasons of use with this prop. Nothing is wrong, just wanting to be sure I am maximizing performance as measured by RPM.
17. No
18. Want to try to get to 5,800 RPM without going down it pitch. It seems that others with a similar set-up get 5,800 RPM with a 19 or 21 pitch prop and I can?t get close with my 15 pitch. Should 5,800 be my target RPM?
19. Not really looking for better cruising speed and fuel savings, but out of curiosity I will eventually post these numbers.
10. No
17. No
