Comparison Tables
zkimball
I've learned so much from these post, but there are ssooooo many props out there and all the adverts say the same things: great hole shot, better mid-range, higher top end, lower fuel consumption, and catch more fish! Each manufacturer makes 5-10 different flavors, and it all runs together.
Is there a chart or table somewhere that lists the intended applications for all the different makes and models?, something that identifies the apples and the oranges and groups them together so I can compare them?
Out of the hundreds of props out there, probably only a few actually fit my needs, (light weight 21CC, 150 Johnson, offshore fishing, better grip on the water at lower speed and RPM.) It's quite difficult, however, to sift through all the information out there; I need to narrow it down.
Thanks again for all you contribute! Z
