collasped fuel line.
82rude
Why would the line coming from the tank to the fuel pump be collapsed on a merc 470?Had the carb rebuilt last week and my brother ran it up to camp and ran great for about 2 hours and now all it will do is idle .As soon as you give her gas she goes about 100 feet and dies.Pump shows 5 psi according to mechanic .Plugged pick up?
Bt Doctur
have never seen the double wall fuel line collapse.More like a clogged anti-syphon
82rude
Thanks I will pass the info on to my brother.Just blow it out.?Is there a filter to replace or?
82rude
Brother says main line was collapsed .Also where would anti siphon line be?
Bt Doctur
it is a spring loaded check ball , the very first fitting at the tank
82rude
Thankyou very much,sounds right.I also checked other sources and the anti-siphon seems to give the exact symptoms so will check asap.
Ayuh,..... It's the hose barb at the tank,....
