Re: Cold starting issue Mercury 1500
how I did my old 1500.
I used a T fitting between the fuel pump and carbs on the upper pump.
fed that to a jonnyrude enrichment valve, cause I had one.
I used the nipples from an old crossflow bypass covers, simply tap them out with a pin punch.
carefuly drill the correct sized hole in the top two carb flanges behind the throttle shutters and install the nipples.
move the existing choke power feed to the solinoid valve.
you will now have a pressure fed fuel primer system.
pump the carb primer,rasise the warmup lever push the choke and it will lght right up.
mine was a hard cold start isue that mysef and a few others, suspect the labyrinth seals on the reed blocks were worn.
after sitting a few weeks it was very hard to start cold, unless you sprayed wd-40 or about anything else into the carbs.
with wd-40 it would light right up.
that 1500 was still runinng a few years back and I did the modification about 1989.
the choke setup on the old inlines as iffy when it worked well.
