Cold start runs rough for short time
Us4parrs
Hey Guys, Im new to this site and could use some help. I went to start up my Volvo Penta 430 4.3l a few weeks ago the the first time for the season. It fired right up with out a hitch, but it idled pretty rough for the first couple minutes, then ran as smooth as silk. I figured from sitting for 6 months it just had to blow the cob webs through. I let it run till full temp and shut it down and pushed it back into the garage. So I went and started it again today, and had the same issues. Im starting to think its not cob webs anymore and wondering if it just needs a new set up plugs, and wires. Or maybe the carb cleaned.
What are you guys thinking it might be?
I greatly appreciate the help. Thank you
Re: Cold start runs rough for short time
Ayuh,.... Welcome Aboard,.... Seein's it clears up after it warms up, I'm thinkin' a choke adjustment might be where to look,...
Wouldn't hurt to pull the plugs, look 'em over, 'n do a compression test,...
Check the distributor cap for corroded contacts,...
Meter the wires, they're probably Ok,..
Change the oil, 'n filter,...
Pull the fuel filter, Inspect it's Contents, 'n throw a new 1 on,...
There's a Summerization thread up in Don'S Adults Only section, have a look,...
Us4parrs
Thank you for the reply.I figured it was carb related. Thinking I might need to replace the u joints too. Got a little bit of knocking noise from the outdrive but goes away when I tilt or trim. Is that fairly simple or a big job? I plan to order a mechanic book.
Thanks
