DJ_Allatoona
Thread starter- Joined
- Feb 24, 2008
- 187
I'm swallowing a little pride here, asking this, but my new (not so new) motor is tough to start cold, and I was wondering if I'm handling it properly. It's a 1986 Mercury outboard, 75 hp, 4-cyl. Here's how I've been starting it cold:
I lower the motor all the way, then pump the fuel bulb until it's firm. Then I raise the fast idle lever all the way, hit the electric choke, and start cranking.
One-one thousand...
Two-one thousand...
Three-one thousand...
Four-one thousand...
Five-one thousand...
Crank, crank, crank...nothing. OK, so I go back to the fuel bulb. It's not firm anymore, so I pump it some more. By now, some fuel is dripping into the water. Back to the key: Choke it, and crank some more.
Crank-crank-crank-crank...(now I'm starting to worry if the battery will hold out)...repeat with the primer bulb.
Crank more. This time after five seconds, maybe I'll get a pop. Crank a couple more seconds, and the motor starts, really rough, and sends out enough smoke to hide a battleship. I keep the fast idle lever up for 10 seconds or so, revving it high, then I lower it. From then on, I'm cool.
Long message, I know, but I envy those guys whose motors fire right up, even ice cold, on the first pop. By the way, and this might be clear, but nobody ever taught me how to start this motor properly.
Appreciate any input. Thanks.
One-one thousand...
Two-one thousand...
