Cold Start issues and idling too fast - 1973 50HP Evinrude Model:50372r
CashesK
Hey everyone. Thanks to anyone who can help diagnose or guide me through the troubleshooting methods
I'm new to boat ownership. I knew my boat would be a abit of maintenance being 1973 but I like to tinker and see the potential in ​this old motor.
Ive fixed the following things so far and this is whats still happening..
Last year it wouldn't turn over at all or hardly unless I wiggled the throttle..obviously a finding neutral issue
fix: Ive removed the old worn out neutral safety switch also I found a short in the remote control body that made the fuse to keep popping.
Now It turns over everytime...but it starst only after 15 mins or 30 mins some of the time if the battery doesn't drain first trying..so cold starting is an issue..
When it does start - it seems ok 90% of the day...after its warm..
this year it seems when it starts the idle speed is super fast... if I try to put it in gear it clunks abruptly into gear obviously from idling to fast..
Ive also found old worn gas lines and replaced them..I changed spark plugs, I changed the sparkplug coils, replaced battery,
and fuel pump assembly
it seems like when its cold it takes a while for fuel to reach the sparkplugs so that is why I replaced the fuel pump but
still I have these two issues..
summers quickly fading away. and it would be nice to get these problems nipped in the butt so I can take her out a few more times this summer.
Any help would be great.. please explain in detail as I'm mechanically inclined but don't know a lot about boat engine repairs..
Thank-you
ondarvr
Have you cleaned the carbs and ensured the choke works correctly?
CashesK
Neither.. How do i check to see choke works.? I have a manual pullout choke on motor and also an auto choke switch under the key. Im pretty sure the auto choke switch doesnt work anymore because i hear nothing or see no movement while flicking it..
So ive been focusing on the manual pull choke. When i pull it out to start. It seems the wire that pushes the choke solonoid rod is
Bendy or sagging a bit so that rod piston that goes into the solonoid moves only slighlty..
And no to carb cleaning. Was hoping i didnt need to rebuild the carbs in first year i have it.
oldboat1
agree with ondarvr. If not quite ready to do carbs, operate the choke manually -- sound like you have to fix the linkage. Taking that much to cold start will wear out your starter.
Additionally, it could be a good idea to pull off the remote cables at the motor, and start the motor using the motor controls -- using the manual choke and making absolutely sure the choke plates close tight. I would take off the air box cover and reach in to make sure they close. Fit the cables to match motor settings when ready to run. If the motor is idling too high, make adjustments at the motor first. The fuel pump isn't an issue with starting -- need to make sure the carb bowls are filled using the primer bulb.
It's standard procedure to check compression and spark using appropriate testers.
CashesK
yes it does feel like it is taking toooo long to start...battery gets discharged and its not a secure feeling being on a lake..if I do get it out there..
How do I go about fixing the linkage..?
The airbox cover is the plate on front of the carbs correct? if I was in the boat staring at the motor .. the air box cover woul dbe facing me with 6 or 8 screws around it correct?
thanks for informing me the fuel pump isn't for starting...
On my particular engine 50 hp 1973 evinrude 50372r how do I adjust the idle? is there screws to turn somewhere I don't see..
near the choke I have a dial to that turns to rich or lean but that doesn't do much to the idle.. I keep that down the middle usually..
thankyou
oldboat1
Let's see, choke linkage is on the side of the carbs, and choke plates are up front in the throats -- need to make sure they shut tight for cold starting. The knob assembly may be the problem, hard to say -- need to check it out (shown in the motor cover diagram). Think I would take off the air box, although you might be able to make adjustments with just the cover removed. Don't confuse the air/fuel mix (carburetor) -- rich/lean settings -- and the idle stop (throttle) -- rpms. That knob you reference is the carb mix adjustment, and it's sensitive -- or should be if the carb is clean. It will definitely affect idling. With the motor warmed up and in gear, you would set it as lean as you can (clockwise) without stalling or lean sneezing, then back it out 1/4 turn. The thottle stop is (I think) on the side of the the powerhead at the throttle linkage, but not sure on your motor.
hope this helps --
http://www.iboats.com/Intake-Manifold/dm/cart_id.041497170--session_id.721186160--view_id.1551311
http://www.iboats.com/Motor-Cover/dm/cart_id.041497170--session_id.721186160--view_id.1551320
CashesK
thanks! Ill look into all this..well my carb must be dirty then if that rich/lean setting doesn't do much.. so I'm zeroing in on the problem...​Ill let you know how things go...
CashesK
If I was missing one of those plastic plugs #14 on the carb drawing you sent would that cause airflow.. and a problem ? because one fell under the motor and i have retrieved it yet..if you say the carb valve needs to be closed tight during cold starts? maybe it lets unnecessary air in?
oldboat1
don't think that plug is a factor -- choke valves are critical, though. Those choke plates or flappers (front of the carbs) must close tightly in the carb throat when you operate the choke. If the plug in the air box cover gives you access to check operation of the flappers, that would be useful.
If there is an airflow problem (say, engine runs better with the box cover off or those plugs removed), the problem is probably the carb venting. If your mix needles aren't working, it's time to pull off the carbs and rebuild them. It takes a couple of carb kits. Soak all metal parts in the solvent of your choice (I use lacquer thinner) Soak the tops and bottoms of carbs, removing the expansion plugs on the tops (replacements in kits). Clean out all small passages with soft wire or a broom bristle, and spray with carb cleaner. I have no particular preference for oem or aftermarket kits, although the oem kits usually contain helpful parts diagrams. It's a good idea to buy kits that contain new floats. I usually eyeball float height, and find that works fine. If the kit comes with rubber tipped float needles and a wire clip, use the clip as the needles can stick (clip goes over the float arm.)
It's easier to do than to describe. Between the choke and the carb, the choke is more important to starting, but unless the carb is clean you won't get good operation.
recka81
This motor is a 65HP but is the same year and I think same setup. The choke solenoid is circled in red. You should be able to buy this part from iboats or marineengine dot com and replace fairly easily. The airbox cover is circled in green. You can see the carb flaps in the open holes in front of each carb and when you pull/push the manual choke lever (bottom front of engine) you should see all these open/close.
Evinrude by Reckerpix
CashesK
Ok. Think ill rebuild carbs. But can i send you a photo or two or a video and you can tell me if my choke linkage looks ok?
Its tough sometimes to see when those diagrams are pulled apart and line drawings.
CashesK
Ive replaced the choke solonoid already last year. But you know what. The piston that goes in n out into it.. And then that thin wire that attaches to that. And to the linkage. That wire seems bendy.. Or too loose so when linkage moves. The piston barely moves..
When i get home ill snap a pic to show you. But to me something doesnt look right.
Should i shorten and tighten that wire?
