cold nature evenrude
jburdette23
Hello
first time at this I have a 84 evenrude 70 it is cold nature from first start up to the last start up. I have to choke it all day, after start up it runs great, but some days its fine with no problems then next time back to choking it. I have had this problem from day 1 (new) have learn to live with it over the years. New fuel lines is the only thing i have replaced on the engine any help on this will be great!
crxess
Re: cold nature evenrude
Sounds like an intermittent loss of fuel pressure. Less fuel means less air needed.(choke)
Need to check for anything blocking/reducing fuel. Check for any air leaks in fuel system.
tashasdaddy
sounds like idle speed adjustment is slow. need to speed up idle just a little. if the only thing that has been replaced is fuel lines, you are overdue for maintainance. carbs cleaned and rebuilt kits, water pump kit, did you now have alcohol resistant fuel lines from tank to carbs.
jburdette23
I rebuilt the carbs replaced all lines installed new water pump. Im still having the same problem even after adjusting the idle up alittle. Im at a dead end maybe primer valve? remember I have had this problem from day 1 back in 1984 when the engine was new
