Coil replacement???
ClassicNoob
I read somewhere in this forum recently that the coil out of my v4a 75 HP Johnson could be replaced with one out of a 1960-somethng pickup truck. Anybody know? I'm trying to get my boat on the water ASAP and I'm hoping I can pick up a coil somewhere locally.
F_R
Honorary Supreme Mariner
It most likely is a car coil, but i can't say for sure what car. But I'd suggest some more testing before throwing parts at it.
1. Pull the spark wire out of the coil tower, then remove the wire from the distributor cap (it un-screws). Now reinsert it into the coil tower and rig up a spark gap off the threaded end. Crank engine and observe for sparks. Should spark four times per revolution. If it does, the points are at least opening and closing, and the coil is working.
2. No sparks? Remove the wire from the negative side of the coil (-) and attach a piece of spare wire to the same coil terminal. Turn the key on and tap-tap the wire spare to ground, observing for sparks as before. Should spark as you do the tap-tap, showing that the coil is working..
3. Still no sparks? Replace (-) wire to coil and check voltage at the coil (+) terminal with key on. Should show about 12V or about 6V depending on whether points are open or closed. No or low voltage? Check ignition switch and wiring to the coil. Keep in mind there is a resistor in the circuit.
4. But got sparks? Check distributor rotor. They are noted for pin-holing and arcing through to the distributor shaft.
These are common tests that any grey-haired car mechanic will be familiar with. After all, it is basically a car system.
Good luck.
Chris1956
If you have the battery/coil/points system, you can replace the condenser and the coil from a car. I used a ford coil, but any matching coil and condenser from a 60's era car would likely work.
Of course, if you have a magneto ignition, you will need a genuine J/E coil, so it will fit inside the distributor body and work properly.
oldboat1
Moisture in the distributor cap could probably be a culprit. Try to dry it out with a hair dryer, then crank it.
ClassicNoob
F_R. I did the testing you described. On step 1 I get a very weak spark. On step 2 I get a more noticable spark. Step 3 yields just over 6 volts. Cap rotor button and points are all dry and free if corrosion... I'm baffled!
