Coil installation
jnicholes
Hello!
I am new to the forum, I just joined today. I have a 1960 Evinrude 75 HP motor. There is no spark going to the spark plugs. I have been working on it for months and I found that electricity is getting to the coil, but not the distributor cap. I did replace the old coil with a new one, but I dont think I installed it correctly. I was wondering if anyone knows how to install a coil like the one I describe. Its part number is 0580243. Here is a link to a picture attached. Can anyone tell me how to properly install one? I am not sure how.
Thanks!
Jared
Note-------That unit does not need 12 volts from a battery to produce the spark !!-------It is expensive.------Best to get this right with a wiring diagram.---------Are you saying that on the bench you get spark from the coil but not from the wires.------If so then look into replacing the rotor.
F_R
1. It is easiest to work on this mag while removed from the motor.
2. Remove distributor cap
3. Make sure the wire is connected to the terminal screw on the side. And that all that stuff is shiny bright clean!
4. Rig up a spark gap between the button on the coil and ground.
5. Rotate pulley. You should get sparks across your spark gap.
6. Got sparks? Everything is good up to that point. Check distributor rotor, cap, and plug wires
7. No sparks? Something is wrong. Check breaker points!!!! Also the shiny bright screw & terminal I mentioned earlier. And make sure it isn't grounded to the case.
jnicholes
Hello!
Thank you SO much for your help! I found the diagram as someone mentioned, and now I am getting spark to my coil. Thanks!
There is just one more problem I need to ask about. Recently I replaced the old spark plug wires with new ones. At the time the only ones available were suppressor wires for a car. Is it possible that these wires are the wrong kind? If so, what wires should I use? If this is not the problem, then it is my distributor cap.
Thanks!
Jared
F_R
Well, you MIGHT get it to run with those resistance wires. But they absolutely are the wrong kind. You need 'wire" wires--the kind with real wire conductors in the middle. If your auto parts store gives you a blank stare, try a local marine shop or lawn mower shop. Another possibility is a tractor supply store. And there always is e-bay. The main problem you are going to have is they have to have those durn screw terminals attached on the ends.
EDIT: Actually, I believe iboats carries a kit with wires and terminals. Check it out.
jnicholes
Hello!
Thanks for that Info! I was wondering what was wrong! I will try replacing the wires and I will get back to you guys on it. I think the cap is still good.
I didn't know Iboats carries stuff like this! I thought it was just a forum!
Thanks!
Jared
