Cordovakid
Thread starter- Joined
- Sep 28, 2012
- 30
I purchased an aftermarket coil for my 25hp Merc. Thecoil came with a soft plastic covering sleeve that fits over the back of the coil (opposite to the wire). My motor's coil setup has a ground plate on the negative terminal with a screw bolt going down through the terminal to mount the coil to the engine ground. This new coil had a smaller ground "strap", which I changed out for my original ground plate with the bolt hole in it. My question is, can I install / operate this coil without the soft plastic covering on the coil - without the cover, it has the exposed shiny off-white plastic hard coating on the top side, and I want to make sure I don't damage the inside of the coil with the pressure of the bolt, or exposing it to the heat of the engine.
